Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Erase all critical station superelevations.
2 REPLIES 2
joantopo
525 Views, 2 Replies
Hi.
I´m using this code snippet (in a button) to delete all critical station superelevations from selected alignment.
 public static void EliminaTodos_PuntosCriticosPeralte(Autodesk.AutoCAD.DatabaseServices.ObjectId identificador)
            //elimina todos los puntos críticos de peralte (critical station) de una alineación para que no quede ninguno.
            try
                Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
                Database db = doc.Database;
                Editor ed = doc.Editor;
                using (DocumentLock docLock = doc.LockDocument())
                    using (Transaction trans = db.TransactionManager.StartTransaction())
                        Alignment align = trans.GetObject(identificador, OpenMode.ForWrite) as Alignment;
                        // get the critical station collection on the aligment.
                        SuperelevationCriticalStationCollection criteriaStationColl = align.SuperelevationCriticalStations;
                        int Total = criteriaStationColl.Count;
                        for (int i = 1; i <= Total - 2; i++)    //el primer y último pk como punto crítico de peralte no se pueden eliminar
                            //eliminamos cada vez el índice 1 porque cuando se elimina un CriticalStation automaticamente el punto siguiente toma el índice anterior,es decir, se ordena la nueva lista según su p.k
                            criteriaStationColl.RemoveAt(1);
                        trans.Commit();
                    }//end using
                }//end lock
            catch (System.Exception ex)
                System.Windows.Forms.MessageBox.Show(ex.Message);
 this code works fine except one thing:
http://thebinarymachine.com/how-to-calculate-superelevation-in-civil-3d/
It says that:
  • If the alignment doesn´t contain any superelevation data a task dialog will be displayed with the following options.
However if I erase all critical station superelevations with my method, then it doesn´t appear that dialog window (Calculate superelevation now) the next times.
In Civil 3D, there is a button to do this and I want to do the same with my button.
I want to do this, because I calculate my own critical station superelevations, but I modify default settings parameters of superelevations and they are used always that we calculate superelevations again.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
2 REPLIES 2
joantopo
in reply to: joantopo
Perhaps it is because in my method I can´t erase critical station superelevations type :
-StartAlignment.
and
-EndAlignment.
They can´t be never deleted.
But Civil 3D has that button to delete all(included those critical station superelevations) critical stations superelevation.
Partha.Sarkar
SuperelevationCriticalStationType.BeginAlignment and SuperelevationCriticalStationType.EndAlignment are also critical stations, but they can’t not deleted using API.
Partha
Partha Sarkar
Developer Technical Services
Autodesk Developer Network
Rail Community
