I need to extract the XY location of a surface label. Specifically, I am trying to determine the coordinates of the first picked point in a two-point slope label. But in looking at the IAeccSurfaceSlopeLabel interface in the ActiveX documentation, I'm not seeing where this data is stored. Even for a simple surface spot elevation label (IAeccSurfaceElevationLabel) I don't see a property that stores the coordinates.
Can anyone point me in the right direction here?
Thank you!
Brent McAnney
Solved by Jeff_M. Go to Solution.
Thanks, Jeff! I have a fairly simple task, so I was hoping to complete this quickly via lisp. But I will take a stab at this tomorrow in .NET.
Could you point me to the class representing the surface slope label? I'm not having any luck so far even finding the proper class to TryCast my selection set objects to.
Well I just found this: http://docs.autodesk.com/CIV3D/2013/ENU/API_Reference_Guide/html/cb79636c-e90e-def7-7e03-005d9400d92...
But I am working in Civil 3D 2011, and that class doesn't seem to exist (at least not in that location). Am I missing something, or is this only possible with newer versions of the API?
You can also get the grip points of the object and use it to find where the label is at. I thought I had an example of it in a blog post, but it looks like I didn't create one. There's a post somewhere either in this group or .NET one where Tony Tanzillo mentioned it in response to one of my questions.
Christopher
