Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Custom sub-assembly codes
2 REPLIES 2
raghulan
7189 Views, 2 Replies
Hello All,
I need some advice on custom sub-assembly codes,
I have gone through the list of codes that is given in the code list.
1. How do I add new code, should I jsut add with the new index at the end
2. What all thinigs I need to update so correct featureline is picked, etc
3. Any examples or help or tutorial on that.
4. Any c# example of building a sub-assembly using .net.
Thanks.
Raghulan Gowthaman Cert IV TAA, B.E,.
Senior Technical Consultant | Developer - R&D
A2K Technologies Sydney
Web : www.a2ktechnologies.com.au
www.civil3dforum.com | www.e4forums.com
www.zcodia.com.au
www.raghulangowthaman.com
2 REPLIES 2
Hi
The Subassemblies codes are read-only, meaning the related methods on the API are only for GET
When creating a new Subassembly, you will probably need the source code to change it, or use the Subassembly composer to add it.
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
Thanks Mate,
 When you say sub-assembly composer to add.
Example,
I created an assembly such as continuous mortor. and I want to create codes such as inner_mortor_edge and outer_mortor_edge.
I add these codes to node in Aubs-assembly composer.
Then do I need to add these entries in the code list file?
Do I need to create a new featureline to associate with the newly created code?
Could you help with this please.
Thanks for your time.
www.zcodia.com.au
Rail Community
