The vertical spacing in curve and line tables (the space between the text and the horizontal line) is too big. This makes the table too long and hard to fit on maps. For regualr tables, you can modify this. However, for curve and line tables this is not available. Is there a .NET file that creates/formats the tables that I could modify to reduce the spacing??
C3D 2012, but the same is true for 2014.
Dave
Thanks Geoff,
I found this workaround but coding is not my area,
https://forums.autodesk.com/t5/civil-3d-customization/civil-3d-point-table-workaround/td-p/5399841
I has a look for an App to but cant seem to find anything.
Obviously it wasn't enough to get something done.
Still no fix to this issue? It's November 2023 and I'm using version 2023 and this issue has been around since 2006!! Bizarre that no resolution from Autodesk has been provided. Regular tables work well, just no flexibility with C3D Point Tables and others. Sad.
They have provided additional work arounds.
1. Use Export to Excel and then link excel to a regular ACad table.
2. Configure project explorer to show the data and copy and paste to excel, then link excel to a regular ACad table.
But a fix ... Seems to be a trend here.
The Project Explorer tables have other issue like the number of decimal points can not be reduced to 2! and the display angle of the bearing also has formatting issues. Exporting to excel and then linking the excel also has other issues.
This table height adjustment appears to be a straightforward fix? But it is not done yet. I am working with C3D 2024 and have the same difficulty of fitting the alignment tag tables onto my sheets.
