Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Creating subassembly using .NET
7 REPLIES 7
Message 1 of 8
Alexey.Terno
2447 Views, 7 Replies
Is it possible to create subassembly from C3D Stock Subassemblies.dll programmatically using .NET?
I need call procedure (BasicLane for example), set all input parameters and create subassembly in drawing.
7 REPLIES 7
Message 2 of 8
Jeff_M
in reply to: Alexey.Terno
Yes. The source code for the Stock Subassemblies is in the C:\Program Files\Autodesk\Autodesk AutoCAD Civil 3D 2014\Sample\Civil 3D API\C3DStockSubAssemblies folder.
Message 3 of 8
Alexey.Terno
in reply to: Jeff_M
Yes, I know it but I need call procedure of this DLL from another DLL.
Message 4 of 8
Alex,
Not sure exactly what you are asking:
> Create a new subassembly
> Use a stock subassembly within a custom subassembly
> Programmatically create an assembly using stock subassembly
What version of C3D are you using? (the answer may vary depending on version)
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
Message 5 of 8
I need programmatically create new assembly using stock subassembly.
C3D2014
VB.NET 2010 - just in case 🙂
Message 6 of 8
I haven't done this myself but I know it is possible from software we had written for us.
Here's the methods:
Import stock subassemly:
http://docs.autodesk.com/CIV3D/2014/ENU/API_Reference_Guide/html/648aeb2b-8729-3cc2-beb6-0a2ce6f24b8...
Add subassembly to assembly:
http://docs.autodesk.com/CIV3D/2014/ENU/API_Reference_Guide/html/73cadec3-9dee-8246-fdf8-652428c9ef2...
Mike Robertson
Message 7 of 8
It's awesome - it really working! Smiley Very Happy
Here working test routine:
        Dim a_CivilDoc As CivilDocument
        a_CivilDoc = CivilApplication.ActiveDocument
        Dim saname As String = "C:\Documents and Settings\All Users\Application Data\Autodesk\C3D 2010\rus\C3DStockSubassemblies.dll"
        Dim classname As String = "Subassembly.BasicLane"
        Dim location As New Autodesk.AutoCAD.Geometry.Point3d(000)
        Dim location2 As New Autodesk.AutoCAD.Geometry.Point3d(10, -0.20)
        Dim q_SubassemblyId As ObjectId
        q_SubassemblyId = a_CivilDoc.SubassemblyCollection.ImportStockSubassembly(saname, classname, location)
        Dim q_SubassemblyId2 As ObjectId
        q_SubassemblyId2 = a_CivilDoc.SubassemblyCollection.ImportStockSubassembly(saname, classname, location2)
        Dim q_Subassembly As Subassembly
        Dim q_Subassembly2 As Subassembly
        Dim q_Assembly As Assembly
        Using a_Transaction As Transaction = _
            HostApplicationServices.WorkingDatabase.TransactionManager.StartTransaction
            q_Subassembly = a_Transaction.GetObject(q_SubassemblyId, OpenMode.ForWrite)
            q_Subassembly2 = a_Transaction.GetObject(q_SubassemblyId2, OpenMode.ForWrite)
            Dim q_Parameters As ParamDoubleCollection
            q_Parameters = q_Subassembly.ParamsDouble
            For i = 0 To q_Parameters.Count - 1
                If q_Parameters(i).DisplayName = "509" Then
                    q_Parameters(i).Value = 5
                End If
            Next
            q_Assembly = a_Transaction.GetObject(a_CivilDoc.AssemblyCollection(0), OpenMode.ForWrite)
            q_Assembly.AddSubassembly(q_Subassembly.Id)
            q_Assembly.InsertSubassemblyAfter(q_Subassembly2.Id, q_Subassembly.Points(3))
            a_Transaction.Commit()
        End Using
 And result:
Assambly
Thanks a lot!
Message 8 of 8
Thanks for sharing your code, this is something we will probably doing pretty soon.
Mike
Mike Robertson
Rail Community
