I am using the GRIPMULTIFUNCTION variable a lot, and was curious if there was a way to create two buttons for = 0 and = 3. This would avoid having to type in that long command, which is easy to misspell.
-D
Civil 3D 2015
x64
Lenovo T440s,
Windows 7
etc etc
Solved by Civil3DReminders_com. Go to Solution.
check out this paper with the info you seek: http://aucache.autodesk.com/au2009/sessions/5097/AU09_SpeakerHandout_CP214-1.pdf
