Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Corridors with Non-Concentric Targets
2 REPLIES 2
412 Views, 2 Replies
I'm trying to figure out if corridors can support non concentric targets correctly through custom sub-assemblies.  The stock sub assemblies only generate geometry perpendicular to the centerline rather than radial to the target polyline or feature line.  I'm wondering if a custom sub assembly can do this, or if other people have solved the problem via a different solution.  Attached are some photos illustrating what I'm referring to.
In "WhatCivilDoes.png" you can see that the corridor extends 0.5' from the flowline perpendicular to the centerline.
In "What I Would Hope to Achieve.png" the Corridor would extend 0.5' radially to the flowline.  This is how the geometry would be generated in a perfect world.
While the difference between the two isn't huge (0.32' is the worst in the above examples), it's enough to make it unusable.
Thanks for the help and/or ideas.
-Mark P.
2 REPLIES 2
Jeff_M
This is what AssemblyOffsets are for.
Jeff_M, also a frequent Swamper
Thanks Jeff!  I feel kinda stupid now though.  As a surveyor, I'm definitely behind the curve when it comes to corridors.  When I asked the engineering department how to accomplish this they told me they didn't know how.
As always I appreciate the help.
-Mark P.
Rail Community
