Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Corridor BaseLine Region
6 REPLIES 6
ebo134
1203 Views, 6 Replies
Hi guys
I have problem with editing start and end station of Corridor Baseline regions,my code doing change but after the finishing the command the changes will not takeplaces ,Can anyone help
thank
here its my code:
 [CommandMethod("CutRegion2")]
        public void CutRegion2()
            Document doc = appy.DocumentManager.MdiActiveDocument;
            CivilDocument cdoc = CivilApplication.ActiveDocument;
            Editor ed = appy.DocumentManager.MdiActiveDocument.Editor;
            Transaction ts = null;
            PointGroup pg = null;
            Alignment al = null;
            using (ts = appy.DocumentManager.MdiActiveDocument.TransactionManager.StartTransaction())
                using (DocumentLock dl = doc.LockDocument())
                    PromptEntityOptions opt = null;
                    PromptDoubleOptions odt1 = null;
                    PromptDoubleOptions odt2 = null;
                    SO so = null;
                    bool flag = true;
                    while (flag)
                        opt = null;
                        so = null;
                        al = null;
                        odt1 = null;
                        odt2 = null;
                        opt = new PromptEntityOptions("\nPlease Select A Corridor");
                        opt.SetRejectMessage("\n... Error, The Selection Must be Corridor!");
                        opt.AddAllowedClass(typeof(Corridor), false);
                        PromptEntityResult ent = ed.GetEntity(opt);
                        if (ent.Status != PromptStatus.OK)
                            flag = false;
                            return;
                        Corridor cor = (Corridor)ent.ObjectId.GetObject(OpenMode.ForWrite);
                        foreach (Baseline bl in cor.Baselines)
                            al = ts.GetObject(bl.AlignmentId, OpenMode.ForWrite) as Alignment;
                            foreach (BaselineRegion br in bl.BaselineRegions)
                                PromptPointOptions ppo = new PromptPointOptions("\nplease, pick a point");
                                ppo.AllowNone = true;
                                PromptPointResult ppr = ed.GetPoint(ppo);
                                if (ppr.Status != PromptStatus.OK)
                                return;
                                double sta1 =0;
                                double sta2 =0;
                                double off=0;
                                al.StationOffset(ppr.Value.X,ppr.Value.Y,ref Sta1,off);
                                return;
                                al.StationOffset(ppr.Value.X,ppr.Value.Y,ref Sta2,off);
                                try
                                    br.SartStation(sta1);
                                    br.EndStation(sta2);
                                    //cor.Rebuild();
                                catch (System.Exception ex)
                                break;
                            break;
                ts.Commit();
6 REPLIES 6
Partha.Sarkar
in reply to: ebo134
You might be selecting values out of range.
Please see the Remarks and Exceptions section for -
BaselineRegion.StartStation  and BaselineRegion.EndStation
http://docs.autodesk.com/CIV3D/2014/ENU/API_Reference_Guide/html/59ca3173-611d-60ca-900c-6481a6d6aac...
Instead of tring the update the values in a for each loop, could you try updating for a single BaselineRegion and check if it updates the values correctly ?
Partha Sarkar
Developer Technical Services
Autodesk Developer Network
I have done a quick test now and I can confirm you they are working fine. I have posted a code snippet in our IM DevBlog :
http://adndevblog.typepad.com/infrastructure/2014/01/updating-civil-3d-corridor-baselineregion-start...
Cheers,
Partha
Partha.Sarkar
in reply to: ebo134
Partha Sarkar
ebo134
in reply to: Partha.Sarkar
than you guys, ok put the code in while loop for multiple corridors and test it if it works ?
thank
ebo134
in reply to: ebo134
Iam sorry for my mistakes, I shouldn't interrupt the transaction procedure with return command,therefore I added ts.Commit(); before every return Command within transaction brackets and it solved my problem, thank you guys.
Partha.Sarkar
in reply to: ebo134
Glad to know that !
Cheers,
Partha
Partha Sarkar
Rail Community
