Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Copy ribbon customizations from regular AutoCAD
3 REPLIES 3
mermerCAD
420 Views, 3 Replies
Hi-
We recently installed Civil 3D on our computers.  Some people started working in regular AutoCAD first rather than changing the workspace in Civil 3D.  They have customized their ribbons.  Is there a way we can copy those customizations and apply them to the 2D Drafting & Annotation workspace in Civil 3D?  Thanks so much!
3 REPLIES 3
You can modify the civil 3d workspace to include the customisation using the cui editor.
You might want to search around a bit on using the cui and customising workspaces. Have a look at the help files and also autodesk university. There are some good class on setting up and customising the cuix's
The amount and type of work you will have to do will depend on the types of customisations they have done.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
Your users can't modify the enterprise cui if you've deployed it that way.... if you deployed with an enterprise cui though, i'd wager you already knew that.
John Hammer, LA/CADD Manager
gccdaemon
in reply to: mermerCAD
Just an FYI, if you're used to working with old MNU style menu's, you can access this data by renaming the CUIX to .ZIP and you'll find the MNU's inside along with the custom icons, etc. You can copy the customizations to the new MNU's in the C3D CUIX, and it should be good. Just make sure to check file pathing.
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
Rail Community
