Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Conditional point/link code in subassembly composer
2 REPLIES 2
viktors.zilinskis
2739 Views, 2 Replies
Hi! I think I saw once somewhere at some blog that it is possible to define point/link codes using some conditional expressions. When I try to write in an expression under "Link Codes" I get an error. Is there a way to create conditional codes without the use of "decisons"? Any ideas would be apprecciated!
BR, Viktors
2 REPLIES 2
I think you'd need to define a variable and the use that variable as the code value. Not ideal, but it's better then managing code set styles for each of the sections.
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
Too bad it does not work to place the function directly in the point/link/shape code. We have still first create a variable with a function.
If it could i can place the function <string.concat( "P2_Side_", Side)> in de point code so each point get automaticaly the name from the side.
Now there is no automaticaly system to give a name from a side position.
Tags (2)
Rail Community
