Hi All,
I can get the northing and easting of an object in Civil3D but it comes without any precision (example: 23234 not 123234.234)
I need to get the NE with 3 decilamal precision. Any idea of how to get it.
Thanks.
Solved by Jeff_M. Go to Solution.
This is not a customization question, please keep base Civil3d questions in the main C3D forum. Thanks!
Check your Settings->Drawing Settings->Ambient Settings->Coordinate precision and/or
The precision fro the label style you are using to label with (you don't say anything about how/what you are looking at for the precision you are seeing).
After rereading the subject line I saw you mentioned .NET...so now I really don't know what you are doing to see what you are seeing. Please be more descriptive with what you are doing. If you have some code, give us a bit of what you are using to get these results....
Sorry if its not clear.
I am getting N and E using .NET C# API.
Thanks mate will give it a go and let you know.
