Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
civil 3d 2014 working plane tool - attention Jeff_M
27 REPLIES 27
Message 1 of 28
neilyj666
906 Views, 27 Replies
Jeff
I tried the working plane tool in 2014 and the tool crashed - I don't have the screengrab of the error handy.
Are you able to take a look to see if there are any issues with 2014?
thanks
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
27 REPLIES 27
Message 21 of 28
Alfred.NESWADBA
in reply to: neilyj666
what path is now shown as not trusted, the one from the ACAD.LSP or the one with the DLL?
And jsut to make sure: when you set SECURELOAD to 0, then restart C3D ... you are also asked?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 22 of 28
neilyj666
in reply to: Alfred.NESWADBA
It works as expected with SECURELOAD=0 but the following whe SECURELOAD=1 - could the double slashes have an effect??
Message 23 of 28
Jeff_M
@neilyj666 wrote:
Yes I think it probably was, although I was meaning about the surface rebuilds rather than the code rebuilds.
Oh, 2 different Rebuilds mentioned and I chose the wrong one to think about. Yes, you are right, it was not an issue while using the old version. It appears to be something wrong with the Rebuild() method of the .NET API which I have inquired about in the other thread I started.
Jeff_M, also a frequent Swamper
Message 24 of 28
Alfred.NESWADBA
I would not think that, but who knows. At least it's not absolutely wrong, but also not absolutely correct to set double slashes.
Either you use single slashes or double backslashes (for the LISP syntax), so try to change them single slashes and lets know if that works then:
(command "_NETLOAD" "C:/AutoLISP/C3D Surface .....
If that also brings up the dialog for trusting the load then try to input the path in the same way with slashes within the trusted paths in the options. (btw. to be sure what and how you have set that now, can you upload a screenshot that shows your trusted paths settings within the options?)
- alfred -
Alfred NESWADBA
Message 25 of 28
neilyj666
Well what a turn up.... single slashes seem to have solved the problem Smiley Happy I don't get the Trusted Location dialog box now and I can run the WorkingPlane commandSmiley Happy
Message 26 of 28
stacy.dunn
in reply to: Jeff_M
Jeff,
Were you able to remove the COM dependencies?  Are you planning to post the source code?
Thank you,
Stacy
Stacy Dunn
Message 27 of 28
Jeff_M
in reply to: stacy.dunn
Yes, Stacy, the current iteration is COM-free. Attached is the current source code which references the 2013 .NET libraries and works in both 2013 & 2014.
Message 28 of 28
stacy.dunn
in reply to: Jeff_M
Thanks again Jeff.
Stacy Dunn
Rail Community
