Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Changing point number
1 REPLY 1
sacprasanna
517 Views, 1 Reply
Hi all,
I  am new to customization world and If bellow thing is possible I can learn.Smiley Happy
I have these point numbers.
Then I add some points.
Then I want to renumber all points 1-9 since there is nine points.
1-1
11-2
2-3
3-4
4-5
5-6
12-7
13-8
6-9
Is there any method using any APIs?
Chamara Prasanna
AutoCAD Civil 3D 2015 SP 1
Sri Lanka
1 REPLY 1
Partha.Sarkar
in reply to: sacprasanna
Hi Chamara Prasanna,
I suggest you look at the following Blog pots by Isaac -
Fun Renumbering Points
Code sample in the above Blog post uses the new COGO Point .NET API in Civil 3D 2013.
If you want to achieve similar in Civil 3D 2012 or earlier release, you could use Civil 3D COM API.
IAeccPoint:: Number Property -> Gets or sets the identifying number assigned to the point.
Hope this helps.
Partha Sarkar
Developer Technical Services
Autodesk Developer Network
Rail Community
