Hi all,
I am new to customization world and If bellow thing is possible I can learn.
I have these point numbers.
Then I add some points.
Then I want to renumber all points 1-9 since there is nine points.
1-1
11-2
2-3
3-4
4-5
5-6
12-7
13-8
6-9
Is there any method using any APIs?
Hi Chamara Prasanna,
I suggest you look at the following Blog pots by Isaac -
Code sample in the above Blog post uses the new COGO Point .NET API in Civil 3D 2013.
If you want to achieve similar in Civil 3D 2012 or earlier release, you could use Civil 3D COM API.
IAeccPoint:: Number Property -> Gets or sets the identifying number assigned to the point.
Hope this helps.
