AutoCAD Civil 3D Customization
Distinguished Contributor
area51visitor
Message 21 of 26 (139 Views)
Re: Centerline Alignment Profile Elevation
07-17-2011 11:18 PM in reply to: Jeff_M
Incredible you learned this on your own Jeff.... your one impressive dude!
- Brian
"Very funny, Scotty. Now beam down my clothes."
area51visitor
Message 22 of 26 (141 Views)
07-17-2011 11:25 PM in reply to: Jeff_M
really appreciate it Jeff... I know you must have worked hard on that...
still would like your advice on where to get after "hello world".  I have a novice understanding of visual basic itself, but not related to autocad. Should I start there?
I'd like to stick with VB... since I'm already slightly familiar with it.
Again, much appreciated!!!
- Brian
Jeff_M
Message 23 of 26 (140 Views)
07-17-2011 11:43 PM in reply to: area51visitor
VB.NET is fine, just I prefer to use C#. That's the nice thing about .NET, you have options.
Try to work through the .NET training: http://images.autodesk.com/adsk/files/autocad_net_training0.zip This contains text and code for using both VB.NET and C#.
Yes, .NET requires you to write more code than lisp would. But, as you've already noticed, .NET is MUCH faster to execute than lisp. See if you can work through the example I posted after using the converter to get it into VB.NET.
I'm offline for the next 8-12 hours, so good luck! Just dig in, it eventually will 'click'.  You can keep on posting where you get stuck, too. Josh is more into VB than I so he may have some other/better information for you.
joshuamodglin
Message 24 of 26 (138 Views)
07-18-2011 05:35 AM in reply to: area51visitor
Since you are interacting with the user (getting a point and getting an entity), it would be good to go through the .Net tutorials that Jeff linked you to. The main page where the download is from is at:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1911627
The .Net training zip is about halfway down the page. This will help you understand the methods available to interact with the user at the command line (through the Editor).
To use this to get the alignment object is shown in the blog post below:
http://www.civil4d.com/2011/02/civil3d-net-getting-the-alignment-station-label-styles/
Josh Modglin
Advanced Technologies Solutions Logo
area51visitor
Message 25 of 26 (127 Views)
07-18-2011 07:37 AM in reply to: joshuamodglin
Awesome... thanks a mill!
- Brian
jmaeding
Message 26 of 26 (120 Views)
07-18-2011 05:03 PM in reply to: peterfunkautodesk
for anyone watching this still, do you know any links that nicely explain good ways of structuring .net stuff?
So you might have functions that do extension methods, then ones that do pdf manipulation, some that do graphics and so on.
I basically use one namespace for all helper functions, and separate into projects and .cs files as it makes sense.
Essentially, its all on root folders with same namespace.
Do you guys separate into folders and use more detailes sub-namespaces?
Do you separate based on what referenced (dependencies) are needed?
Do you separate on items you can share, as opposed to proprietary ones?
I think half of any language is building on past stuff, and even beginners need things like extension methods set up.
Lookin for ideas.....
