Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Can’t Launch AutoCAD Civil 3D 2011 when I use VBDotNetClientSample project
7 REPLIES 7
Message 1 of 8
nestxanh
972 Views, 7 Replies
Can’t Launch AutoCAD Civil 3D 2011 when I use VBDotNetClientSample project (AutoCAD Civil 3D 2011/Sample/Civil API/Com..) with VB.Net 2008.
References:
Error:
After that I intall AutoCAD Civil 3D 2010 and launch again and it still run properly with that project
Please help me with using and running AutoCAD Civil 3D 2011!
Thanhks!
7 REPLIES 7
Message 2 of 8
Jeff_M
in reply to: nestxanh
The references for the 2 AEC*, and 2 AECC* libraries are all for the 2010 product. You will need to change these to use the 2011 versions (6.5, 8.0).
Additionally, if you installed the 64 bit version of C3D2011 then those libraries did not get registered. Search back a few weeks, there was a link posted to the 2011 API webcast. That link also has a download for the registry entries.
HTH
Jeff_M, also a frequent Swamper
Message 3 of 8
nestxanh
in reply to: Jeff_M
Thanks you very much
:D,  I did again according to your advice but the project still error.
AutoCAD Civil 3D 2011 was activated in Task Manager but it disappeared in tmg after a while and the project reported an error:
Please kindly help me again.
Message 4 of 8
Jeff_M
OK, I went ahead and opened the project here. I am getting the same result as you.....I'm not sure at this point what the problem is.
Message 5 of 8
nestxanh
Thanhs!
When you find the reason made that error, plese let me know. I'm too! 😄
Message 6 of 8
MikeEvansUK
Not getting this error when I run it but it was loading 2010 instead of 2011.(expect you don't have 2010 on the PC)
If I change the following lines:
        m_sAcadProdID = "AutoCAD.Application"
        m_sAeccAppProgId = "AeccXUiLand.AeccApplication.7.0"
to
        m_sAcadProdID = "AutoCAD.Application.18.1"
        m_sAeccAppProgId = "AeccXUiLand.AeccApplication.8.0"
Then it runs 2011 as expected.
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Message 7 of 8
Jeff_M
in reply to: MikeEvansUK
That is precisely what I did, Mike. It no worky here on C3D2011-64bit.
Message 8 of 8
MikeEvansUK
Yep, youre quite right.
It seems that it works under XP but not under windows 7 x64.
I wonder why?
Mike Evans
Rail Community
