Autodesk.AutoCAD.DatabaseServices.Entity ent= trans.getObject( Id,OpenMode.ForRead) as Entity, if "id" belongs to a Feature Line ?
and
Autodesk.AutoCAD.DatabaseServices.DBObject obj= trans.getObject( Id,OpenMode.ForRead) as DBObject if "id" belongs to a Feature Line ?
There are ambiguous namespaces and I don´t know if I can use feature lines/survey figures in the same DatabaseServices from Autodesk.AutoCAD instead Autodesk.Civil3d.
I have a lot of functions that use line/arc/polyline/pol3d and feature line entities and I don´t know if I have to check what is every entity with ObjectClass.DxfName="......" first and then apply: "getObject" .
Solved by Jeff_M. Go to Solution.
