Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Can I do this? (My own CogoPointCollection)
3 REPLIES 3
joantopo
388 Views, 3 Replies
I´m trying to create a new instance of class "CogoPointCollection" but Visual Studio say me that CogoPointCollection doesn´t have a defined builders.
  public static CogoPointCollection Get_CogoPointColl(ObjectIdCollection IdColl)
             Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            Database db = Application.DocumentManager.MdiActiveDocument.Database;
            Autodesk.Civil.ApplicationServices.CivilDocument civDoc = default(Autodesk.Civil.ApplicationServices.CivilDocument);
            civDoc = Autodesk.Civil.ApplicationServices.CivilApplication.ActiveDocument;
            CogoPointCollection CogoPointColl = new CogoPointCollection();
            foreach (ObjectId pointId in IdColl)
                CogoPoint CP = pointId.GetObject(OpenMode.ForRead) as CogoPoint;
                double X = CP.Easting;
                double Y = CP.Northing;
                double Z = CP.Elevation;
                Autodesk.AutoCAD.Geometry.Point3d point = new Autodesk.AutoCAD.Geometry.Point3d(X, Y, Z);
                CogoPointColl.Add(point);
 Can I create my own CogoPointCollection or it´s only to get CogoPoint Collection in Database?
Thank you.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
3 REPLIES 3
zrobert
in reply to: joantopo
You can't create instance of CogoPointCollection class.
But, you can create simple ObjectIdCollection or ObjectId[] to hold ObjectId's
of your CogoPoints objects, and then you can create CogoPoint objects from this Id's
inside of Transaction.
Another way is to create generic list to hold CogoPoint objects:
var cogoPointCollection = new List<CogoPoint>();
and then add CogoPoints to list inside of your loop:
cogoPointCollection.Add(point);
After that, you can iterate through this collection and do things on CogoPoint objects.
Just remember that object created inside of transaction, live as long as live transaction.
joantopo
in reply to: zrobert
Ok. I undestand it now.
I always use List for all. This time I´m going to use a List too.
I want to compare location cogopoints from Group Point versus location vertex of breaklines.
Thank you.
zrobert
I'm glad that I help.
Cheers...
Rail Community
