I´m trying to create a new instance of class "CogoPointCollection" but Visual Studio say me that CogoPointCollection doesn´t have a defined builders.
public static CogoPointCollection Get_CogoPointColl(ObjectIdCollection IdColl) { Editor ed = Application.DocumentManager.MdiActiveDocument.Editor; Database db = Application.DocumentManager.MdiActiveDocument.Database; Autodesk.Civil.ApplicationServices.CivilDocument civDoc = default(Autodesk.Civil.ApplicationServices.CivilDocument); civDoc = Autodesk.Civil.ApplicationServices.CivilApplication.ActiveDocument; CogoPointCollection CogoPointColl = new CogoPointCollection(); foreach (ObjectId pointId in IdColl) { CogoPoint CP = pointId.GetObject(OpenMode.ForRead) as CogoPoint; double X = CP.Easting; double Y = CP.Northing; double Z = CP.Elevation; Autodesk.AutoCAD.Geometry.Point3d point = new Autodesk.AutoCAD.Geometry.Point3d(X, Y, Z); CogoPointColl.Add(point); } }
Can I create my own CogoPointCollection or it´s only to get CogoPoint Collection in Database?
Thank you.
Solved by zrobert. Go to Solution.
You can't create instance of CogoPointCollection class.
But, you can create simple ObjectIdCollection or ObjectId[] to hold ObjectId's
of your CogoPoints objects, and then you can create CogoPoint objects from this Id's
inside of Transaction.
Another way is to create generic list to hold CogoPoint objects:
var cogoPointCollection = new List<CogoPoint>();
and then add CogoPoints to list inside of your loop:
cogoPointCollection.Add(point);
After that, you can iterate through this collection and do things on CogoPoint objects.
Just remember that object created inside of transaction, live as long as live transaction.
Ok. I undestand it now.
I always use List for all. This time I´m going to use a List too.
I want to compare location cogopoints from Group Point versus location vertex of breaklines.
Thank you.
