Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
C3D 2012 SP2, they did it again!
3 REPLIES 3
Jeff_M
456 Views, 3 Replies
Installing this service pack breaks the ability to build my 2012 VS projects, ala SP1 the exact same fix applies to the latest SP (edit the registry values for the 3 AEC COM objects to show the version as 6.7.49, NOT the 6.7.20X it gets set to with the SP2).
Jeff_M, also a frequent Swamper
3 REPLIES 3
Partha.Sarkar
in reply to: Jeff_M
Hi Jeff,
I am working with QA team on this issue and I will update you all soon.
Partha Sarkar
Developer Technical Services
Autodesk Developer Network
CADUSER2009
in reply to: Jeff_M
I cannot believe this is happening again. After installing SP2 my .NET code won't compile because it can't find AecXBase and AecXUIBase. I'm totally gobsmacked that Autodesk have done it again.
Partha.Sarkar
in reply to: CADUSER2009
Resolution given in the following Blog post should fix the issue related to SP2 also.
http://adndevblog.typepad.com/infrastructure/2012/05/cannot-build-civil-3d-2012-com-with-net-code-af...
Please let me know if anyone needs help here.
Partha Sarkar
Rail Community
