AutoCAD Civil 3D Customization
Valued Mentor
kevin.barnett
Message 1 of 7 (182 Views)
Accepted Solution
C3D 2012 Sampleline Station change
182 Views, 6 Replies
11-05-2012 08:49 PM
Greetings,
C3D 2012
c#
I am trying to change the station of a sample line with code.
I could not find the property in the managed reference, but it appears to be available in the COM.
COM help under SampleLine properties:
LockToStation.. Gets or sets the boolean value that specifies whether the sample line is locked to the station.
Station ...  Gets or sets the alignment station for this sample line.
In my code I set LockTostation to false then alter the station value, but ... the SampleLine station does not change.
What have I missed?
Thx.
Kevin.
Problem located ... the station equation were 'incorrect' like this:
C3D/the API refuses to change the sample line object stations in these regions UNTIL all columns (raw station back, station back, and station ahead) have the same values - then it works ..  like this ..
ADN Support Specialist
Partha.Sarkar
Message 2 of 7 (176 Views)
Re: C3D 2012 Sampleline Station change
11-05-2012 10:53 PM in reply to: kevin.barnett
Hi Kevin,
It seems you have taken the right steps. Check if you have given a valid Station value.
I have blogged a code snippet here :
http://adndevblog.typepad.com/infrastructure/2012/11/editing-station-property-of-a-sampleline-using-...
Hope this helps!
Partha Sarkar
Developer Technical Services
Autodesk Developer Network
Valued Mentor
kevin.barnett
Message 3 of 7 (175 Views)
11-05-2012 11:02 PM in reply to: Partha.Sarkar
The only difference I can see is ... You have a trans.commit() line after the sample station property setting. I do not have transaction defined in my code, did not know it was needed for COM. I could not see the definition of the trans variable in the example. How is it defined? Thx, Kevin..
Partha.Sarkar
Message 4 of 7 (170 Views)
11-06-2012 03:27 AM in reply to: kevin.barnett
Dim trans As Transaction = HostApplicationServices.WorkingDatabase.TransactionManager.StartTransaction()
Partha Sarkar
Valued Mentor
kevin.barnett
Message 5 of 7 (165 Views)
11-06-2012 04:39 AM in reply to: kevin.barnett
I have now tested the code on new drawings, the code works, sample line stations update/change.. it is not working in the work drawing where I need it to work… will post when I discover the problem preventing the station change..
Valued Mentor
kevin.barnett
Message 6 of 7 (161 Views)
11-06-2012 05:41 AM in reply to: kevin.barnett
Aha!!! The alignment has station equations when I remove some the problem is resolved in the region without station equations ... will continue research tomoro ...
Valued Mentor
kevin.barnett
Message 7 of 7 (154 Views)
11-06-2012 09:01 PM in reply to: kevin.barnett
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
