Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
C# TinSurface Export to postgis
1 REPLY 1
441 Views, 1 Reply
I want to export one TInSurface to postgis database.
Todo that,  i have to split the TinSurface to several polyline3D or Polygon3D  geometry? How can i get that ? (i only have TinSurfaceTriangle)
Or maybe if TIN geometry exist for Postgis ?
TinSurface aSurface = (TinSurface)tr.GetObject(surfaceId, OpenMode.ForRead);
TinSurfaceTriangleCollection triangleCollection = aSurface.GetTriangles(false);
foreach (TinSurfaceTriangle triangle in triangleCollection)
1 REPLY 1
Jeff_M
Not sure what postgis requires, but you could get the contours as polylines, or create 3 sided polygons from the Triangle data, or a few other methods exist as well. This is what I do to create Faces for use in machine control:
        public static DBObjectCollection ExtractFaces(this TinSurface surf)
            DBObjectCollection faces = new DBObjectCollection();
            foreach (TinSurfaceTriangle triangle in surf.GetTriangles(false))
                Face face = new Face(triangle.Vertex1.Location, triangle.Vertex2.Location, triangle.Vertex3.Location, true, true, true, true);
                faces.Add(face);
            return faces;
Jeff_M, also a frequent Swamper
Rail Community
