Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
C# DotNetComInterop Sample
5 REPLIES 5
tomg
544 Views, 5 Replies
Getting started with DotNet. I am trying to run the C# DotNetComInterop sample in VS 2010. References to AecXBase and AecXUIBase are unresolved.  Both type libraries are in the C:\Program Files\Common Files folder. The error list states the components could not be found. The registry shows Version 6.7.107.0 for both components.
Has anyone seen this or know the solution?
Tom
Win 7 C3D 2012 SP1 (64 Bit)
5 REPLIES 5
Jeff_M
in reply to: tomg
Delete those 2 references and add them back in using the COM tab.
tomg
in reply to: Jeff_M
Had tried that. No joy.
I tried again - Still can't find them.
Tom
Jeff_M
in reply to: tomg
I'd forgotten about this.....If you have installed SP1 you will need to apply the REG file patch which I've attached. For the background on this:
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-Customization/NET-on-C3D-2012-SP1/td-p/3239048
tomg
in reply to: Jeff_M
Jerff,
That did the trick. Now I'm off to discover .NET in C3D.
Tom
Jeff_M
in reply to: tomg
Glad I could help! Have fun and feel free to ask about any issues you run into.
If you find a response which answers your question, please be sure to accept that response as the solution. This will help future searchers quickly find answers to their own questions. Thanks!
Rail Community
