The AutoWideningCriteriaInfo Class has the property: MinimumRadiusTableName
How I can use that property?
I have a list with the alignments but I would like a list with the table name for each alignment.
I have this:
public static CivilDocument m_doc = Autodesk.Civil.ApplicationServices.CivilApplication.ActiveDocument;
public static ObjectIdCollection oAlignments = m_doc.GetAlignmentIds();
but tthis property does not allow to the object alignment.
This class only serves for offset alignments or is useful for standard alignments?
Because it saids:[quote]This class encapsulates the properties that are necessary to add an autowidening from a criteria file. It is used by the OffsetAlignmentInfo::AddAutoWidenings() method.[/quote]
Why the class Aignment doesn´t have that property (CriteriaInfo) and the subproperties?
For Aignments only exists the properties:
UseDesignCriteriaFile (bool var)
CriteriaFileName
I want know the minimum radius table name about standard alignment.¿?
Hi joantopo,
Yes, going by the Civil 3D .NET API Reference doc, it says -
I don't see the properties like 'Minimum Radius Table', 'Transition Length Table', 'Attainment Method' etc. which are part of 'Default criteria' are exposed in current release of Civil 3D. I am logging a wish list to expose these in future release of Civil 3D.
Partha Sarkar
