I have made same autolisp routine, but one function same times return deferent results on the same input.
This this a function:
(defun GetBlockName (coordinatesList pointList / blockNameList x y ent entname blockName) (setq blockNameList (list)) (while (and (setq x (car coordinatesList)) (setq y (cadr coordinatesList))) (setq point (car pointList)) (setq ent (ssget "_C" (list (- x 0.5) (- y 0.5)) (list (+ x 0.5) (+ y 0.5)) '((2 . "PIKETAS")))) (if (= ent nil) (progn (setq ent (ssget "_C" (list (- x 0.5) (- y 0.5)) (list (+ x 0.5) (+ y 0.5)) '((2 . "Grezinys")))) (if (= ent nil) (setq blockNameList (append (list (list (list "Nerasta") (list x y) point)) blockNameList)) (progn (setq blockName (FindBlockAttribute ent "NR")) (setq blockNameList (append (list (list (list blockName) (list x y) point)) blockNameList)) ) ) ) (progn (setq blockName (FindBlockAttribute ent "NUMERIS")) (setq blockNameList (append (list (list (list blockName) (list x y) point)) blockNameList)) ) ) (setq ent nil) (setq coordinatesList (cddr coordinatesList)) (setq pointList (cdr pointList)) ) (reverse blockNameList) )
results of function run two times on same data:
blockNameList((("Nerasta") (431460.0 6.03049e+006) (432336.0 6.03032e+006)) (("Nerasta") (431463.0 6.03049e+006) (432330.0 6.03034e+006)) (("Nerasta") (431505.0 6.03044e+006) (432267.0 6.03036e+006)) (("Nerasta") (431517.0 6.0304e+006) (432227.0 6.03039e+006)) (("Nerasta") (431552.0 6.03037e+006) (432175.0 6.03043e+006)) (("47_84") (431570.0 6.03033e+006) (432136.0 6.03047e+006)) (("13_00") (431557.0 6.03028e+006) (432078.0 6.03046e+006)) (("2_00") (431506.0 6.03021e+006) (431995.0 6.03042e+006)) (("33_84") (431503.0 6.03015e+006) (431935.0 6.03037e+006)) (("9_00") (431450.0 6.03007e+006) (431837.0 6.03019e+006)) (("5") (431391.0 6.02999e+006) (431741.0 6.03021e+006)) (("Nerasta") (431387.0 6.02999e+006) (431733.0 6.03019e+006)))
blockNameList((("Nerasta") (431460.0 6.03049e+006) (432416.0 6.03039e+006)) (("17_00") (431463.0 6.03049e+006) (432410.0 6.03041e+006)) (("7") (431505.0 6.03044e+006) (432347.0 6.03043e+006)) (("14_00") (431517.0 6.0304e+006) (432307.0 6.03047e+006)) (("8") (431552.0 6.03037e+006) (432255.0 6.0305e+006)) (("47_84") (431570.0 6.03033e+006) (432216.0 6.03055e+006)) (("13_00") (431557.0 6.03028e+006) (432158.0 6.03054e+006)) (("2_00") (431506.0 6.03021e+006) (432075.0 6.0305e+006)) (("33_84") (431503.0 6.03015e+006) (432015.0 6.03044e+006)) (("9_00") (431450.0 6.03007e+006) (431917.0 6.03027e+006)) (("5") (431391.0 6.02999e+006) (431821.0 6.03028e+006)) (("Nerasta") (431387.0 6.02999e+006) (431814.0 6.03027e+006)))
blockNameList consisting of input data and additional data.
("Nerasta") - this is additional data.
(431460.0 6.03049e+006) - data from coordinatesList
(432336.0 6.03032e+006) - data from pointList
pointList is not used in any calculations in this function, so it is uninportant. Only coordinateList is used for finding additional data. But I don't get why giving the same coordinates I get different results.
Hi, You will undoubtedly get more repsonse to this if you move it over to the plain Autocad Lisp Customization forum where there are lots of lisp gurus. Have you stepped through the code in the VLIDE to watch what it is doing differently?
how do I move this topic to AutoCAD Lisp forum? Does here are special move function, or do I need to create new topic in Lisp forum and dellete this topic?
I was stepping through my lisp routine to find this function, but did not had more time to go deeper in. Because wrong result don't came always. Same times you need a lot of trials. So it takes time to stepp through it, But I guess it must be (ssget) function.
I was going through code in VLIDE and found out that problem are in this line
Some times it will return nil even if all are given the same as last time. I went through code several times and had found it will start to return nil randomly, but if you slow down it will return selection set.
I had put breakpoint near this funktion and was going through it fast by presing Crtl + F8, when it started to return nil, I slowed down and started to get selection sets and not nil.
