Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
AutoCAD Civil 3D : Creating Bearing / Distance Table Using Points
2 REPLIES 2
amartinez475
742 Views, 2 Replies
Hi: I'm new using Civil 3D 2014. I know how to label a line with bearing and distance. What I would like to do is make a table with these bearings and distances referencing the point numbers. like this:
COURSE       BEARING              DISTANCE     PT#     NORTHING    EASTING
1053-1055 N 89d25'56" W        8.49        1055     67966.60    168121.99
Its a close polyline that represent a parcel land.
Please help.
thanks
2 REPLIES 2
You will get more responses in the General Civil 3D forum. Look under the Annotate tab of the Ribbon, on the left hand side is a button to label lines and curves (including polylines). You can then create a table (using the button right next to it) to create the table. Help will have more detailed information.
rkmcswain
in reply to: amartinez475
I do not see any way to include what you call the "course" (start and ending point numbers) in a traditional line tag table. Below are the choices for the what you can include in a table column.  As far as I know, Civil3D does not know/maintain/monitor relationships between line endpoints and cogo points.
R.K. McSwain     | CADpanacea | on twitter
Rail Community
