Hi: I'm new using Civil 3D 2014. I know how to label a line with bearing and distance. What I would like to do is make a table with these bearings and distances referencing the point numbers. like this:
COURSE BEARING DISTANCE PT# NORTHING EASTING
1053-1055 N 89d25'56" W 8.49 1055 67966.60 168121.99
Its a close polyline that represent a parcel land.
Please help.
thanks
You will get more responses in the General Civil 3D forum. Look under the Annotate tab of the Ribbon, on the left hand side is a button to label lines and curves (including polylines). You can then create a table (using the button right next to it) to create the table. Help will have more detailed information.
I do not see any way to include what you call the "course" (start and ending point numbers) in a traditional line tag table. Below are the choices for the what you can include in a table column. As far as I know, Civil3D does not know/maintain/monitor relationships between line endpoints and cogo points.
