Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
API for PointLabelStyle
10 REPLIES 10
Message 1 of 11
511 Views, 10 Replies
As there appears to be no API for Point label style how do you code to allow
the user to select a point label style from a list box and then create a
point using that style?
As an alternative (since I know how I want the label to appear), can I
create a label style with code and assign that to the point I create.
The points hold program assigned descriptions, which cannot readily be
allowed for with a Description Key set.
Laurie Comerford
www.cadapps.com.au
10 REPLIES 10
Message 2 of 11
I spoke too early. I seem to be able to populate the list box with:
Dim oStyle as Object
For Each oStyle in g_oAeccDoc.PointLabelStyles
Listbox.AddItem oStyle.Name
etc
and the following code works:
oPoint.LabelSyle = g_oAeccDoc.PointLabelStyles.Item(Listbox.Value)
Laurie
"Laurie Comerford" wrote in message
news:5255742@discussion.autodesk.com...
Laurie Comerford
www.cadapps.com.au
Message 3 of 11
nzeeben
I am not doing much other than looking but does
collection.points.item(x).labelstyle not get you what you need? You will
have to assign the style after you create the point, but it seems to me it
is there? Maybe I missed the point entirely.
Nick
Laurie Comerford
www.cadapps.com.au
Message 4 of 11
Hi Nick,
Thanks for the response. As you can see from my second post, you are right.
The mistake I made was not to look under the Document Object for the Point
Label Styles.
Laurie Comerford
CADApps
www.cadapps.com.au
wrote in message news:5255738@discussion.autodesk.com...
Nick
Laurie Comerford
www.cadapps.com.au
Message 5 of 11
Thanks much for posting your solution, Laurie.
news:5255757@discussion.autodesk.com...
etc
Message 6 of 11
nzeeben
The documentation is so wonderful for the api.
news:5255929@discussion.autodesk.com...
Hi Nick,
Label Styles.
Laurie Comerford
CADApps
www.cadapps.com.au
Nick
Laurie Comerford
www.cadapps.com.au
Message 7 of 11
Sinc
I can't get this to work.
When I access the AeccDoc.PointLableStyles collection, all it has in it is the top-level styles. All children are missing.
How do I get a complete list of Point Label Styles, including all children?
(using .NET)
Sinc
Message 8 of 11
The LabelStyle Object has a Children property:
Children Gets the collection of all label styles derived directly or indirectly from this label style.
wrote in message news:5790225@discussion.autodesk.com...
missing.
(using .NET)
Message 9 of 11
This subject came up a few weeks back at a
customer meeting.
Their in-house C3D programmer that uses the
supporting code and libraries I build for them,
told me there was a bug in my code. 😮
He was passing it the objects in the collection
returned by the PointLabelStyle's, 'Children'
property, but did not see all of the derived
styles displayed in the UI.
As it turns out, the PointLabelStyle's 'Children'
property doesn't do what its description says
it does.
The 'Descendents' and 'Children' properties have
their descriptions reversed. Children contains only
directly-derived styles. Descendents contains both
directly- and indirectly-derived styles, as the name
implies.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
"Jeff Mishler" wrote in message news:5790349@discussion.autodesk.com...
missing.
(using .NET)
Message 10 of 11
Sinc
OK, I am now able to get the list of styles.
However, if I try to change the current PointLabelStyle programmatically, I can only get it to work if I set it to a top-level style. Otherwise, I get an exception thrown on an "invalid parameter".
Is there some trick to setting the current PointLabelStyle to a style that is not a top-level style?
Sinc
Message 11 of 11
Given the documentation bug, it's possible that the
programmer that wrote that is incorrectly testing the
value you pass in for membership in the Children
collection rather than the Descendents collection.
wrote in message news:5796326@discussion.autodesk.com...
Rail Community
