Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Any samples of "FindStationAndElevationAtXY()" method?
2 REPLIES 2
joantopo
500 Views, 2 Replies
C#
public bool FindStationAndElevationAtXY(
	double x,
	double y,
	ref double station,
	ref double elevation
I don´t understand this method. API documentation says that "Finds the station and elevation values at the given X,Y coordinate." but this method return a bool value.
I don´t understand neither "ByRef".
Any samples please?
Thank you.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
2 REPLIES 2
joantopo
in reply to: joantopo
   Point3d pt = ed.GetPoint("\nClicka un punto sobre la visualización del perfil: ").Value;
                double elevacion=0;
                double pk=0;
                 pv.FindStationAndElevationAtXY(pt.X, pt.Y, ref pk, ref elevacion);
I think the API Ref document has very clear explanation on this :
public bool FindStationAndElevationAtXY(  double x,  double y,  ref double station,  ref double elevation )
Parameters
x Type: System.Double
The X coordinate in the profile view's coordinate system.
y Type: System.Double
The Y coordinate in the profile view's coordinate system.
station Type: System.Double
Returns the corresponding station.
elevation Type: System.Double
Returns the corresponding elevation.
I see you already resolved it, however, any feedback to us to improve the API documentation is always welcome !
Cheers,
Partha
Rail Community
