Using Civil 3D 2016- Analyze command-
How do I increase the precision of results when choosing a line or arc with the "Analyze" command? Would like to see degrees and bearings to 4 decimals in seconds, distances to at least 6 decimal places. And NO... "Units" does not appear to affect the output (unless you use the "List" command, which kind of defeats the purpose of having the "Analyze" option).
Solved by Jeff_M. Go to Solution.
Thanks, all is well with the world again. Will change my templates, and post this answer to my Wall of Arcane Knowledge.
