Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Add more than one handler for specific event.
1 REPLY 1
joantopo
757 Views, 1 Reply
Hi.
I have method (GetAlineaciones) = GetAlignments to get all alignments in active document.
  public static List<Alignments> GetAlineaciones()
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;  // por si queremos preguntar o responder en la línea de comandos
            Database db = Application.DocumentManager.MdiActiveDocument.Database;
            Autodesk.Civil.ApplicationServices.CivilDocument civDoc = default(Autodesk.Civil.ApplicationServices.CivilDocument);
            civDoc = Autodesk.Civil.ApplicationServices.CivilApplication.ActiveDocument; //obtener el documento de Civil
            ObjectIdCollection alignColl = civDoc.GetAlignmentIds();  //obtener la colección de alineaciones
            if (alignColl.Count == 0)  //alignColl=align collection
                return null;
            List<toolsC3D.Alignments> aligns = new List<toolsC3D.Alignments>();   // instancia de la nueva lista
            Alignments aBobj = default(Alignments);
            using (Transaction trans = HostApplicationServices.WorkingDatabase.TransactionManager.StartTransaction())
                int i = 0;
                foreach (ObjectId id in alignColl)  // para cada alineación abierta para leer
                    try
                        Alignment align = trans.GetObject(id, OpenMode.ForRead) as Alignment;
                        aBobj = new toolsC3D.Alignments();
                        aBobj.Id = align.Id;
                        aBobj.IdString = align.Id.ToString(); //tendremos el Id también como string
                        //aBobj.IndiceFila = i; //posición que ocupa en la lista empezando por 0
                        aBobj.Name = align.Name;
                        aBobj.Description = align.Description;
                        aBobj.CriteriaFileName = align.CriteriaFileName;
                        aBobj.DesignCheckSetName = align.DesignCheckSetName;
                        aBobj.Length = align.Length;
                        aBobj.UseDesignCriteriaFile = align.UseDesignCriteriaFile;
                        aBobj.UseDesignCheckSet = align.UseDesignCheckSet;
                        aBobj.AlignmentType = align.AlignmentType;
                        aBobj.StartingStation = align.StartingStation;
                        aBobj.EndingStation = align.EndingStation;
                        aBobj.stringStartingStation = functions.funciones_genéricas.formatoPK(align.StartingStation);  //string p.k inicial
                        aBobj.stringLength = functions.funciones_genéricas.stringdecimales(align.Length,variables_globales.decimalesLongitud) + " m."; //string
                        aBobj.DesignSpeedCollection = align.DesignSpeeds;  // la colección de los tramos de Vp
                        if (align.SuperelevationCriticalStations.Count < 2)  //si count=0 es que no se ha calculado. Si es count=2 se calculó pero se han eliminado los puntos críticos y sólo queda el inicial y final de alineación
                           aBobj.CalculoPeraltes = "No";
                      else
                            if (align.SuperelevationCriticalStations.Count == 2)
                                aBobj.CalculoPeraltes = "**Sin datos**";
                            else
                                aBobj.CalculoPeraltes = functions.FunctionsPeraltes.DevolverNombreCurva(functions.FunctionsPeraltes.NombreCurvaPrimera(align.Id),align.Id);
                        aligns.Add(aBobj);  // se va añadiendo cada alineación, con sus propiedades, a la lista(aligns)
                        i++;
                        if (variables_globales.regenAlinAUTO == true)
                            //permitimos los eventos (+=)
                            Document doc = Application.DocumentManager.MdiActiveDocument;
                                align.Erased += new ObjectErasedEventHandler(TypeViewer.TypeViewerControl.ProcesRegenAlin);
                                // align.Reappended += new EventHandler(TypeViewer.TypeViewerControl.ProcesRegenAlin); //si se elimina del dibujo y se vuelve a recuperar con un "deshacer" ctrl+z
                                //align.Unappended += new EventHandler(TypeViewer.TypeViewerControl.ProcesRegenAlin);
                                align.Copied += new ObjectEventHandler(TypeViewer.TypeViewerControl.ProcesRegenAlin);
                                doc.Database.ObjectModified += new ObjectEventHandler(callback_ObjectModified);
                                doc.CommandEnded += new CommandEventHandler(callback_CommandEnded);
                                //align.Modified += new EventHandler(callback_ObjectModified);
                        else
                    catch
            return aligns;
However, I want add more than one handler (one for each alignment) for specific event.
If one alignment has already one handler (for example ObjectModified) I don´t want to add again  the same handler.
Now, I have this in this method:
                        else
 I have read this:
http://adndevblog.typepad.com/autocad/2013/04/removing-all-custom-handlers-of-an-event.html
and I have read about: GetInvocationList() but I don´t understand it.
Thank you.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
1 REPLY 1
In this case, why not track the events at the Database level? That way you track all and avoid duplicated handles...
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
Rail Community
