Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
About AddAllowedClass()
1 REPLY 1
joantopo
678 Views, 1 Reply
Hi.
I have this:
  Autodesk.AutoCAD.Internal.Utils.SetFocusToDwgView();
       Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
       Database db = doc.Database;
       Editor ed = doc.Editor;
       Autodesk.Civil.ApplicationServices.CivilDocument civilDoc = default(Autodesk.Civil.ApplicationServices.CivilDocument);
       civilDoc = Autodesk.Civil.ApplicationServices.CivilApplication.ActiveDocument; //obtener el documento de Civil
       PromptEntityOptions entOpts = new PromptEntityOptions(" Selecciona una superfície del dibujo <vuelve a la paleta>: ");
       var _with1 = entOpts;
       _with1.SetRejectMessage("no es una objeto superfície.");
       _with1.AddAllowedClass(typeof(Autodesk.Civil.DatabaseServices.TinSurface), true);
       _with1.AllowNone = true;
       _with1.AllowObjectOnLockedLayer = true;
       PromptEntityResult entRes = ed.GetEntity(entOpts);
       if (entRes.Status != PromptStatus.OK)
           return;
  using (DocumentLock docLock = doc.LockDocument()) //bloqueo
           using (Transaction trans = HostApplicationServices.WorkingDatabase.TransactionManager.StartTransaction())
               Autodesk.Civil.DatabaseServices.Surface sup = default(Autodesk.Civil.DatabaseServices.Surface);
               sup = trans.GetObject(entRes.ObjectId, OpenMode.ForRead) as Autodesk.Civil.DatabaseServices.Surface;
               Autodesk.AutoCAD.Geometry.Point3dCollection pt3dcoll = new Point3dCollection();
 I get a surfaceID from selected  TIN surface in drawing, although I want to can also select a GRID surface.
How can I modify this code line to allow both classes? (TinSurface and GridSurface)
 Thank you.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
1 REPLY 1
Jeff_M
in reply to: joantopo
just add another line for that AddAllowedClass...
_with1.AddAllowedClass(typeof(Autodesk.Civil.DatabaseServices.GridSurface), true);
Rail Community
