Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Abbreviation Settings Update
4 REPLIES 4
RodWing
840 Views, 4 Replies
This is similar to my previous post about the Ambient settings. In Civil 3D 2014 I am also trying to update the Abbreviation settings. As with the Ambient settings, the first running updates the Abbreviation settings without any problem. On a subsequent running I get a NULL exception on the SetAlignmentEnhancedAbbreviation method. Creating a new drawing with the Client's template and running this generates the exception the first time through.
I suspect that the cause of this error is the same as the Ambient setting problem.
  Private Function UpdateAbbreviationSettings(ByRef civDoc As Autodesk.Civil.ApplicationServices.CivilDocument) As Boolean
        Dim i As Integer
        Dim iStart As Integer
        Dim iEnd As Integer
        Dim strValue As String
        UpdateAbbreviationSettings = False
        Try
            Dim abAlgET() As Autodesk.Civil.Settings.AbbreviationAlignmentEnhancedType
            abAlgET = {Autodesk.Civil.Settings.AbbreviationAlignmentEnhancedType.AlignmentBeginningPoint, _
                   Autodesk.Civil.Settings.AbbreviationAlignmentEnhancedType.AlignmentEndPoint, _
                   Autodesk.Civil.Settings.AbbreviationAlignmentEnhancedType.CompoundSpiralLargeRadiusAtBeginning, _
                   Autodesk.Civil.Settings.AbbreviationAlignmentEnhancedType.CompoundSpiralLargeRadiusAtEnd, _
                   Autodesk.Civil.Settings.AbbreviationAlignmentEnhancedType.CompoundSpiralSmallRadiusAtBeginning, _
                   Autodesk.Civil.Settings.AbbreviationAlignmentEnhancedType.CompoundSpiralSmallRadiusAtEnd, _
                   Autodesk.Civil.Settings.AbbreviationAlignmentEnhancedType.CurveBeginning, _
                   Autodesk.Civil.Settings.AbbreviationAlignmentEnhancedType.CurveEnd, _
                   Autodesk.Civil.Settings.AbbreviationAlignmentEnhancedType.LineBeginning, _
                   Autodesk.Civil.Settings.AbbreviationAlignmentEnhancedType.LineEnd, _
                   Autodesk.Civil.Settings.AbbreviationAlignmentEnhancedType.SimpleSpiralLargeRadiusAtBeginning, _
                   Autodesk.Civil.Settings.AbbreviationAlignmentEnhancedType.SimpleSpiralLargeRadiusAtEnd, _
                   Autodesk.Civil.Settings.AbbreviationAlignmentEnhancedType.SimpleSpiralSmallRadiusAtBeginning, _
                   Autodesk.Civil.Settings.AbbreviationAlignmentEnhancedType.SimpleSpiralSmallRadiusAtEnd _
            iStart = LBound(abAlgET)
            iEnd = UBound(abAlgET)
            For i = iStart To iEnd
                strValue = civDoc.Settings.DrawingSettings.AbbreviationsSettings.AlignmentGeoPointEntityData.GetAlignmentEnhancedAbbreviation(abAlgET(i))
                If strValue = "ABC" Then
                    civDoc.Settings.DrawingSettings.AbbreviationsSettings.AlignmentGeoPointEntityData.SetAlignmentEnhancedAbbreviation(abAlgET(i), "XYZ")
                Else
                    civDoc.Settings.DrawingSettings.AbbreviationsSettings.AlignmentGeoPointEntityData.SetAlignmentEnhancedAbbreviation(abAlgET(i), "ABC")
            Next
            UpdateAbbreviationSettings = True
        Catch ex As Exception
        End Try
    End Function
Again, any help would be most appreciated.
Thanks.
Rod Wing
4 REPLIES 4
Jeff_M
in reply to: RodWing
Rod, if you would use Imports and variables so you could shorten the code it would be much easier to read/follow. This code does so and is working for me in 2014, running multiple times and verifying the values are changing from to ABC, then XYZ, then ABC again.
        Private Function UpdateAbbreviationSettings(ByRef civDoc As CivilDocument) As Boolean
            Dim abbrevs = civDoc.Settings.DrawingSettings.AbbreviationsSettings.AlignmentGeoPointEntityData
            Try
                Dim abAlgET() As String
                abAlgET = [Enum].GetNames(GetType(AbbreviationAlignmentEnhancedType))
                For Each enumname In abAlgET
                    strValue = abbrevs.GetAlignmentEnhancedAbbreviation([Enum].Parse(GetType(AbbreviationAlignmentEnhancedType), enumname))
                        abbrevs.SetAlignmentEnhancedAbbreviation([Enum].Parse(GetType(AbbreviationAlignmentEnhancedType), enumname), "XYZ")
                    Else
                        abbrevs.SetAlignmentEnhancedAbbreviation([Enum].Parse(GetType(AbbreviationAlignmentEnhancedType), enumname), "ABC")
                Next
            Catch ex As SystemException
            End Try
        End Function
Jeff_M, also a frequent Swamper
RodWing
in reply to: Jeff_M
Thanks for the condensed code.
I copied your code into my module, but still get the same result. It modifies the value to ABC the first time. When I save the drawing and run it again it throws a NULL Exception when trying to change the value to XYZ.
Jeff_M
I've just run it a dozen times, saving between each run, no problems. Perhaps something else in the rest of your code is going awry and not being exposed until it gets to this function.
RodWing
in reply to: Jeff_M
I found that setting CommandFlags.Session in the CommandMethod causes the Exception. If I remove it the function runs fine. That bings up another issue in that I need to execute this on multiple documents. Something else I will have to deal with.
Thank you for your assistance Jeff.
Rail Community
