I need 54" Pipe for a water line I am designing but C3D 2013 Pressure Pipes only goes up to 48".
Is there a way to create a 54" Pressure Pipe that behaves the same way that the other Pipes
do in the C3D 2013 Pressure Pipe program?
Thanks in advance.
I presume you want to create the new pipe using Civil 3D Pressure Pipe UI tool / command and not using API.
This particular forum is focused on Civil 3D programming / customization / API. I would suggest you to post your question to Civil 3D User group and you might see a quick response from one of the expert users in the forum.
Go to civil 3d 2014, the catalog have until 1600 mm, or 64" on Ductile Iron
