Josh, this is identical to how coordinates are returned for *Polylines.
Here's a quick example that works with any single dimension array. Pass the
listarray, the index(0 based) of the coordinate you want and the number of
items in the coordinate (a LWPoly returns them in XY whereas a 3dpoly &
FeatureLines return XYX)...For example, to get the fourth coordinate of a
XYZ list:
Dim vCoords As Variant
vCoords = oent.Coordinates
Dim testPt As Variant
testPt = GetCoordinates(vCoords, 3, 3)
[code]
Function GetCoordinatesFromArray(vCoordList As Variant, iIdx As Integer,
iXYZ As Integer) As Variant
Dim vPt() As Double
Dim iCtr As Integer
Dim I As Integer
iCtr = iIdx * iXYZ
ReDim vPt(0 To (iXYZ - 1))
For I = 0 To iXYZ - 1
vPt(I) = vCoordList(iCtr)
iCtr = iCtr + 1
Next
GetCoordinates = vPt
End Function
[/code]
"jlund" wrote in message news:5909920@discussion.autodesk.com...
> here is what I have so far. . . When I place a watch on varPoints, it
> returns varPoints(0 to 20) of what appears to be coordinates (7 PIs on the
> FL). The problem is each value is a separate element in the array. For
> example varPoints(0) is the easting of hte first point and varpoints(1) is
> the norting. . . varPoints(3) starts the coords of a new PI. How do I
> break down the elements of the array to get coordinates triples?
> Sub FLInfo()
> On Error GoTo ErrLabel
> If getCivilObjects = True Then
> Dim objFL As AeccLandFeatureLine
> Dim cFL As AeccLandFeatureLines
> Set cFL = g_oAeccDb.Sites("Site 1").FeatureLines
> Set objFL = cFL.Item(0)
> Debug.Print objFL.ElevationPointsCount & " - ElevationPointsCount"
> Debug.Print objFL.PointsCount & " - PointsCount"
> Debug.Print objFL.Length3D & " - Length3D"
> Debug.Print objFL.PIPointsCount & " - PIPointsCount"
> Dim varPoints As Variant
> varPoints = objFL.GetPoints(aeccLandFeatureLinePointPI)
> End If
> Exit Sub
> ErrLabel: MsgBox Err.Description & " " & Err.Source
> End Sub
