I am getting an "Active X can't create Object" error with this code. It is VBA with ACA2013. I have the enabler installed. I am building a routine that will ultimately be in VB.net but I can't get off the starting block.
References:
AECXUiArchBase
AECXArchBase
AECXUiBase
AECXBase
AutoCad2013 Type Library
Visual Basic for Applications
OLE automation
My code (with the line with the error marked.:
Public Sub CreateLayers()
Dim oDoc As AecArchBaseDocument
Dim o_dbPref As AecArchBaseDatabasePreferences
Dim cLayerKeyStyles As AecLayerKeyStyles
Dim oLayerKeyStyle As AecLayerKeyStyle
Dim cLayerKeys As AecLayerKeys
Dim oLayerKey As AecLayerKey
Dim oLayer As AcadLayer
'Activate the AEC Document using the AecArchBaseApplication
Set oDoc = AecArchBaseApplication.ActiveDocument '------>>>ActiveX Can't create Object<<<<<<----------
'Activate the AEC Preferences Collection
Set oPref = oDoc.Preferences
'Activate the LayerKeyStyles collection
Set cLayerKeyStyles = oDoc.LayerKeyStyles
'Sets the layer key style to the current layer standard
Set oLayerKeyStyle = cLayerKeyStyles.Item(oPref.LayerStandard)
'Message for verification
MsgBox "The current Layer Key Style is: " & o_dbPref.LayerStandard, _
vbInformation, "Current Layer Key Style"
'Activate the Keys collection of the current layer standard
Set cLayerKeys = oLayerKeyStyle.Keys
'Message for varification
MsgBox "The current number of layer keys is: " & o_cLayerKeys.Count, _
vbInformation, "Current Layer Key Count"
'Clean up all your declared objects
Set oLayer = Nothing
Set cLayerKeys = Nothing
Set oLayerKeyStyle = Nothing
Set cLayerKeyStyles = Nothing
Set oPref = Nothing
Set oDoc = Nothing
End Sub
