AutoCAD Architecture Customization
Welcome to Autodesk’s AutoCAD Architecture Customization Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture Customization topics.
Updating Property in Objects Definition in XREF DWGs
1 REPLY 1
375 Views, 1 Reply
I am developing an simulation application, leveraging on using Space objects and applied additional Property Set Definitions for Space objects where I introduced a new Property "Value".
I applied a display theme to my DWG, and based on the value of the Property, different colours wil be displayed according to the display theme.
For a single DWG file containing the building, I am able to simulate the colour changes by updating the “Value” Property in the Spaces using .NET APIs functions such as PropertySet.SetAt, and commiting the transasction.
However, one building can consist of many different levels, and I have split up the modeling of the building into its separate levels.
For example, a 3 storey building, I will have 3 DWG files for each individual levels.
A main empty DWG was then used to XREF the 3 levels, to combine the different levels into a whole building.
I would like to simulate such colour change through the main DWG which references my individual level DWGs.
Any idea what .NET API I can use to access the XREF DWGs in my main DWG, so that I can update the "Value" property in all my Space objects?
1 REPLY 1
jeff
For vanilla cad it works great but XrefGraph class might work in AEC
You can also find your answers @ TheSwamp
”Boost
