AutoCAD Architecture Customization
Welcome to Autodesk’s AutoCAD Architecture Customization Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture Customization topics.
Two 'Graphic Property Definitions' set by formula property.
3 REPLIES 3
mdhutchinson
765 Views, 3 Replies
Is there a way to control which of two 'Graphic Property definitions' are used via a formula property with a IF, Then, condition statement?
3 REPLIES 3
David_W_Koch
in reply to: mdhutchinson
Not so far as I know.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
mdhutchinson
in reply to: David_W_Koch
Yeh, that's what I am seeing.
See this:
http://www.jtbworld.com/images/adt2007schedule.gif
How is the image getting switched up?
David_W_Koch
While you can set a default image in the Property Set Definition, you need to assign the image associated with a specific instance (for an object-based PSD) or style (for a style-based PSD).  The Schedule Table will show the image associated with the object(s) on a particular row.
David Koch
Blog | LinkedIn
”Boost
