Please help me.When i open drawing,text size change bigger.I reduce normally size,and close.After that i open again text size change bigger.
Are you using AutoCAD Architecture or just vanilla AutoCAD?
Are the text items that appear large annotative? Are you showing all annotative objects, or only those for the current scale? Is the current drawing scale attached to these items, or do they only have a different scale attached, that would result in larger than expected text?
What are you doing to reduce the text to normal size? It does not appear to get saved with the file.
Can you attach a sample file to a reply post, that exhibits the problem?
