AutoCAD Architecture Customization
Welcome to Autodesk’s AutoCAD Architecture Customization Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture Customization topics.
Space Object Elevation Property
2 REPLIES 2
Keith.Brown
1989 Views, 2 Replies
I am trying to create a property definition that will display the elevation of a space object.  I looked through the automatic properties and did not find anything that looked like the elevation.
I have tried the following but was unable to achieve any success.
RESULT="--"
On Error Resume Next
Set AcadApp = GetObject(, "AutoCAD.Application")
Set Obj = AcadApp.Activedocument.Objectidtoobject("[ObjectID]")
RESULT = Obj.elevation
That formula does work if i swap elevation with say height, width,length or any of the properties found in the automatic property list that are a single word.  I know the elevation is there I just don't know how to access it.
Any ideas?
2 REPLIES 2
Keith.Brown
in reply to: Keith.Brown
I thought I would post the solution that I finally found for this issue.  The property that I really needed for the space object was its location.  The above method did not work because Location is a 3D vector and needed to be converted to an array.  Below is the solution that works for me.  Kudos to Hallex for pointing me in the right direction for another issue that led me to the solution to this problem.
Set acadApp = GetObject(,"AutoCAD.Application")
'ACADVER values:
'ACA 2010 = "18.0s (LMS Tech)"
'ACA 2011 = "18.1s (LMS Tech)"
'ACA 2012 = "18.2s (LMS Tech)"
'ACA 2013 = "19.0s (LMS Tech)"
acadVerString = acadApp.ActiveDocument.GetVariable("ACADVER")
'Set ACA application string, based on version running:
Select Case acadVerString
	Case "18.0s (LMS Tech)"  'ACA-2010
		aecBaseVer = "AecX.AecBaseApplication.6.0"
	Case "18.1s (LMS Tech)"  'ACA-2011
		aecBaseVer = "AecX.AecBaseApplication.6.5"
	Case "18.2s (LMS Tech)"  'ACA-2012
		aecBaseVer = "AecX.AecBaseApplication.6.7"
	Case "19.0s (LMS Tech)"  'ACA-2013
		aecBaseVer = "AecX.AecBaseApplication.7.0"
	Case "19.1s (LMS Tech)"  'ACA-2014
		aecBaseVer = "AecX.AecBaseApplication.7.5"
	Case Else
		aecBaseVer = "Unknown"
End Select
If aecBaseVer = "Unknown" Then
	RESULT = "Unknown Version"
Else
	' Get an Utility object to convert the Vector3D to an Array
	Set aecBase = acadApp.GetInterfaceObject(aecBaseVer)
	aecBase.Init acadApp
	Set SpaceObject = acadApp.ActiveDocument.ObjectIDToObject([ObjectID])
	Set UtilityObject = aecBase.ActiveDocument.Utility
	' Get the Location of the Object and break down into individual X, Y, and Z parts
	SpaceObjectLocation = UtilityObject.ConvertToVariantArray(SpaceObject.location)
	LocationX = SpaceObjectLocation(0)
	LocationY = SpaceObjectLocation(1)
	LocationZ = SpaceObjectLocation(2)
	'Return the results
	RESULT = CStr(LocationZ)
End If
freedom1k
Thanks for the update Keith. I had an older version from DKoch. I took out the "CStr" conversion in the Results, so that my Data Formats are respected on objects.
”Boost
