I would like to know if anyone knows how to set or change the active display configuration with .NET. Currently I am sending this task to the command line. See below:
' This subroutine sets the correct display config with the supplied name Public Sub SetCurrentDisplayConfig(ByVal strDisplayConfig As String) Dim strCommand As String = "" strCommand = "-AECDISPLAYCONFIGSETCURRENT " & strDisplayConfig & vbCr AutoApp.Application.DocumentManager.MdiActiveDocument.SendStringToExecute(strCommand, True, False, False) End Sub
Look at the AecDisplaySampleMgd in Sample folder(located in installation folder)
and
http://www.theswamp.org/index.php?topic=36679.msg416795#msg416795
