AutoCAD Architecture Customization
Welcome to Autodesk’s AutoCAD Architecture Customization Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture Customization topics.
Set active Display Configuration with .NET
2 REPLIES 2
jsebclark_SDG
677 Views, 2 Replies
I would like to know if anyone knows how to set or change the active display configuration with .NET.  Currently I am sending this task to the command line.  See below:
' This subroutine sets the correct display config with the supplied name
        Public Sub SetCurrentDisplayConfig(ByVal strDisplayConfig As String)
            Dim strCommand As String = ""
            strCommand = "-AECDISPLAYCONFIGSETCURRENT " & strDisplayConfig & vbCr
              AutoApp.Application.DocumentManager.MdiActiveDocument.SendStringToExecute(strCommand, True, False, False)
        End Sub
2 REPLIES 2
in reply to: jsebclark_SDG
Look at the AecDisplaySampleMgd in Sample folder(located in installation folder)
and
http://www.theswamp.org/index.php?topic=36679.msg416795#msg416795
jsebclark_SDG
Thank you for the info.  I will try this out today.
”Boost
