AutoCAD Architecture Customization
Welcome to Autodesk’s AutoCAD Architecture Customization Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture Customization topics.
Retrieving Value in PropertyDefinitionLocation
1 REPLY 1
502 Views, 1 Reply
Hi.
I am working on extracting information from DWG with extended Property Set Definitions.
I have added Location Property on my Door objects, and would like to retrieve it in my application.
Definition as shown in AutoCAD > Manage > Style Manager > Property Set Definitions
DoorObjects Property Set
Description: Space - SpaceObjects - SpaceID
Type: Location (becomes Automatic inside .NET API code)
Source: Space - SpaceObjects - SpaceID
Space Objects Property Set
Description: SpaceID
Type: Integer
I have tried the .NET API. see Code below. I am stuck at PropertyDefinitionLocation. Not too sure where I can retrieve the value for my AtSpaceID at my DoorObjects.
Any one has experience in doing so? Please advice. Thanks.
I tried the following code below and it throws error such as eInvalidInput or eNotApplicable.
Part of my code
Door doorEntity = trans.GetObject(doorObjID, OpenMode.ForRead) as Door;
ObjectIdCollection idsPropSet = PropertyDataServices.GetPropertySets(doorEntity);
foreach (ObjectId idPropSet in idsPropSet)
    PropertySet propSet = trans.GetObject(idPropSet, OpenMode.ForRead) as PropertySet;
    PropertySetDefinition propSetDef = trans.GetObject(propSet.PropertySetDefinition, OpenMode.ForRead) as PropertySetDefinition;
    PropertyDefinitionCollcetion propDefs = propSetDef.Definitions;
    foreach (PropertyDefinition propDef in propDefs)
        if(propDef.Automatic)   //the Space
            ObjectIdCollection idsDummy = new ObjectIdCollection();                                              if(propDef.GetType().ToString().Equals("Autodesk.Aec.PropertyData.DatabaseServices.PropertyDefinitionLocation"))
                PropertyDefinitionLocation propDefLoc = propDef as PropertyDefinitionLocation;
                //this give me eInvalidInput error
                MessageBox.Show(propSetDef.GetValue(propDefLoc.Id, doorObjId, idsDummy).ToString());
                //give me Automatic Property -- not applicable in this context
                MessageBox.Show(propDefLoc.FormatId, idsDummy).ToString());
1 REPLY 1
jeff
Small change
   Door doorEntity = tr.GetObject(id, OpenMode.ForRead) as Door;
                            PropertySet propSet = tr.GetObject(idPropSet, OpenMode.ForRead) as PropertySet;
                            PropertySetDefinition propSetDef = tr.GetObject(propSet.PropertySetDefinition, OpenMode.ForRead) as PropertySetDefinition;
                            PropertyDefinitionCollection propDefs = propSetDef.Definitions;
                                if (propDef is PropertyDefinitionLocation)   //the Space
                                        //this does NOT give me eInvalidInput error
                                        MessageBox.Show(propSetDef.GetValue(propDef.Id, id, idsDummy).ToString());
You can also find your answers @ TheSwamp
”Boost
