AutoCAD Architecture Customization
Welcome to Autodesk’s AutoCAD Architecture Customization Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture Customization topics.
References for 3.0 and 3.3
5 REPLIES 5
241 Views, 5 Replies
Tell me if I am doing this correctly. I need to reference the
AecsXBase30.tlb file (the 3.0 version) in VB so users of 3.0 can use my
programs. What I did was have someone email me the file from a 3.0
installation and saved this under the Command\Autodesk Shared\ADT30
directory. Now I go into References and Browse for the TLB file. Once i
select it i return back to the References list and it stille say
: Description : "AEC Base 3.3 Object Library" : String :
ThisDrawing.AcadDocument_ObjectAdded
: FullPath : "C:\Program Files\Common Files\Autodesk Shared\AecXBase30.tlb"
Does this name still show up due to registry settings ADT setup during
install.
Second question.
what reference file do i need for this to work?
TypeOf object Is AecGeo
I think it is the one i talked about above.??????
TIA
Rob Starz
Plogv 3.0 & 2000 (plot logging) for r14 & 2000
***Enhancement Tools for Arch. Desktop *****
!!!! DormerX out in Sept !!!!
http://www.stardsign.com/main.htm
5 REPLIES 5
on top of this do i need to get the associated DLL file also to compile
correctly?
Rob Starz
"Rob Starz" wrote in message
news:D0929F1AD30A2C6AE757961F8D84034E@in.WebX.maYIadrTaRb...
> install.
> Second question.
> TIA
> Rob Starz
Rob,
I think you should be set with what you have. And yes, the AecBase Object
library is the one that contains the AecGeo Class
Cheers,
Peter Funk
API Product Manager
Building Industry Division
Autodesk, Inc.
news:45763BDDAAA2A589CD5376914D00FEA5@in.WebX.maYIadrTaRb...
> correctly?
> Rob Starz
i
> > install.
> > Second question.
> > TIA
> > Rob Starz
you mean the changes i have made or the files should work as installed?
Rob Starz
The changes that you made to reference the 3.0 type library.
Peter
news:038D2F0DC4C9016E571CBD0B00B66ADD@in.WebX.maYIadrTaRb...
Object
> Rob Starz
great...we'll see how much the testers like it.
thanks Peter.
Rob Starz
"Peter Funk - Autodesk, Inc" wrote in message
news:C993B4AF4DA7DC171F638441FB0765D6@in.WebX.maYIadrTaRb...
> Peter
> Object
> > Rob Starz
”Boost
