AutoCAD Architecture Customization
Welcome to Autodesk’s AutoCAD Architecture Customization Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture Customization topics.
Property Set Value From Style Using Property Set Name
4 REPLIES 4
Hugh_Compton
1786 Views, 4 Replies
I use the following function to return the Proerty Set values of a property set when knowing it's name.  Does anyone know how to get it working for style based PSDs?
Public Function GetValuesFromPropertySetByName(ByVal pname As String, ByVal dbobj As AcadDb.DBObject) As System.Collections.ArrayList
        Dim setIds As ObjectIdCollection = AecPropDb.PropertyDataServices.GetPropertySets(dbobj)
        Dim values As System.Collections.ArrayList = New System.Collections.ArrayList()
        If setIds.Count = 0 Then
            Return values ' just return emtpy collection...
        Dim db As Database = HostApplicationServices.WorkingDatabase
        Dim tm As acDS.TransactionManager = db.TransactionManager
        Dim psId As ObjectId
        For Each psId In setIds
            Dim pset As AecPropDb.PropertySet = tm.GetObject(psId, OpenMode.ForRead, False, False)
            Dim pid As Integer
            Try
                pid = pset.PropertyNameToId(pname)
                values.Add(pset.GetValueAndUnitAt(pid))
            Catch e As Autodesk.AutoCAD.Runtime.Exception
                ' most likely eKeyNotfound.
            End Try
        Next
        Return values
    End Function
4 REPLIES 4
Keith.Brown
in reply to: Hugh_Compton
The AecPropertySampleMgd in the Sample folder in the AutoCAD directory shows how to do just about everything with property sets including getting information from style based property sets.
In particular checkout the GetPropertySetsFromStyle method.  It shows how to get all of the style property sets of an entity knowing only the entities ObjectId.
Hugh_Compton
in reply to: Keith.Brown
Thanks Keith - almost got it working now but it doesn't seem to report values from Property Sets that use formulas:
  Private Function Get_Value_From_Automatic_PropertySet_By_Name(ByVal idSM As ObjectId, ByVal pname As String) As String
        Dim tr As Transaction = db.TransactionManager.StartTransaction
        Dim result As String = ""
        Try
            Dim bt As BlockTable = CType(tr.GetObject(db.BlockTableId, OpenMode.ForRead, False), BlockTable)
            Dim btr As BlockTableRecord = CType(tr.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForRead, False), BlockTableRecord)
            ' get the property sets collection on this entity
            Dim ent As Object = tr.GetObject(idSM, OpenMode.ForRead)
            ' MH: this is for entity.
            ' Dim idsPropSets As ObjectIdCollection = PropertyDataServices.GetPropertySets(ent)
            ' now, try with styles.
            Dim geoObj As Autodesk.Aec.DatabaseServices.Geo = CType(ent, Autodesk.Aec.DatabaseServices.Geo)
            Dim style As Object = tr.GetObject(geoObj.StyleId, OpenMode.ForRead)
            Dim idsPropSets As ObjectIdCollection = PropertyDataServices.GetPropertySets(style)
            ' how many property sets does it have?
            ' ed.WriteMessage(vbCrLf + vbCrLf + ent.GetRXClass.Name + " (" + ent.Handle.ToString + ") has " + _
            'idsPropSets.Count.ToString + " PropSets:")
            ' Loop all PropertySets
            Dim idPropSet As ObjectId
            Dim iPropSet As Integer = 0
            For Each idPropSet In idsPropSets
                iPropSet += 1
                Dim propSet As PropertySet = CType(tr.GetObject(idPropSet, OpenMode.ForRead), PropertySet)
                ' The trick to get the properties is to really loop the *definitions*!
                ' Then we can evaluate automatic ones from the very PropSetDef,
                ' or get static ones from PropSet
                Dim propSetDef As PropertySetDefinition = _
                CType(tr.GetObject(propSet.PropertySetDefinition, OpenMode.ForRead), PropertySetDefinition)
                Dim propDefs As PropertyDefinitionCollection = propSetDef.Definitions
                'ed.WriteMessage(vbCrLf + vbCrLf + " PropSet " + iPropSet.ToString + "[" _
                '+ propSetDef.Name + "] has " + propDefs.Count.ToString + " Props:")
                ' Loop all properties in the propSetDef
                Dim propDef As PropertyDefinition
                Dim iProp As Integer = 0
                For Each propDef In propDefs
                    iProp += 1
                    Dim value As String
                    If (propDef.Automatic) Then 'AUTOMATIC
                        Dim idsDummy As ObjectIdCollection = New ObjectIdCollection()
                        value = propSetDef.GetValue(propDef.Id, idSM, idsDummy).ToString
                        'ed.WriteMessage(vbCrLf + " " + iProp.ToString + _
                        '".(AUTO) Name=" + propDef.Name + " Value=" + value)
                        If propDef.Name = pname Then
                            Return value
                Next propDef
            Next idPropSet
            Return result
            tr.Commit()
        Catch
            Return Nothing
            tr.Abort()
        Finally
            tr.Dispose()
        End Try
    End Function 'Gets an automatic property set value.  Won't work on formula property sets.  Returns nothing if empty
Keith.Brown
I use this code snippet to get the value from a property set definition.  It doesnt matter if it is automatic, formula, manual, etc.  It just gets the value.
Sorry the code is in C#.  Im too lazy to convert it.
private static List<ToolTipLine> GetPropertySetValues(Member member, PropertySetDefinition propertySetDefinition)
            // List to hold the property set definitions to display in the tooltip
            List<ToolTipLine> list = new List<ToolTipLine>();
            try
                using (
                    Transaction transaction =
                        member.Database.TransactionManager.StartOpenCloseTransaction())
                    // Check to see if the Property Set is attached to the object.  If it is not then
                    // Just return a blank list.
                    ObjectId propertySetId = PropertyDataServices.GetPropertySet(member, propertySetDefinition.Id);
                    if (propertySetId.IsNull || propertySetId.IsErased)
                        return list;
                    PropertySet propertySet = transaction.GetObject(propertySetId, OpenMode.ForRead) as PropertySet;
                    // Iterate through each property definition in the property set
                    foreach (PropertyDefinition propertyDefinition in propertySetDefinition.Definitions)
                        try
                            // Make sure that the property set defintion is set to visible
                            if (propertyDefinition.IsVisible)
                                // Get the ObjectID of the property set definition
                                int propertyId = propertySet.PropertyNameToId(propertyDefinition.Name);
                                // Get the value of the property definition
                                object value = propertySet.GetAt(propertyId);
                                string str = "";
                                if (value != null)
                                    str = value.ToString();
                                // Once the value of the property definition is known we can create a new item
                                // For our list.
                                ToolTipLine item = new ToolTipLine
                                    Name = propertyDefinition.Name,
                                    Value = str,
                                    Order = propertyDefinition.DisplayOrder
                                // Add the item to the list
                                list.Add(item);
                        catch
                    propertySet.Dispose();
                    // Sort the list of items so that they respect the order assigned in the property set definition
                    list.Sort();
            catch
            finally
            return list;
The code is a little specific for what I am using it for but it does show how to get the value of any property definition.
Hugh_Compton
Looks promising - will report back later when tested - urgent job on at the mo'!  Mine is for a tooltip too.
Thanks K
”Boost
