AutoCAD Architecture Customization
Welcome to Autodesk’s AutoCAD Architecture Customization Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture Customization topics.
Property Set Help
0 REPLIES 0
Message 1 of 1
Keith.Brown
263 Views, 0 Replies
Property Set Help
I would like to create an automatic tag that will give the elevation of the bottom of a piece of steel.  In particular I-shaped beams.  In order to do this I need access to the depth of the steel.  This is not available in the properties of the steel when I try to add an automatic property source.  I know that the information is availabe cause I can see it in the Structural Member Catalog as the "A-Depth" column.  Is there a way to access this information?  I am sure that it involves scripting of sometype but I have no idea on where to start.  I am new to scripting property definitions and this is my first project.  Any help that can be given would be appreciated.
0 REPLIES 0
”Boost
