AutoCAD Architecture Customization
Active Contributor
0 Kudos
Post 1 of 4
Property Set Definition "if a number equals text"
566 Views, 3 Replies
08-08-2012 09:53 AM
Hi All,
I having problems trying to resolve a formula in the property definitions. I have a field that has USAGENO 060, 050 that the user inputs. But I would like to auto populate another field ROOMNAME with its corresponding text, to reduce input and avoid user error. The number always equals a room name as shown below.
060=Office
050=Lobby
I tried on the ROOMNAME field this but its not working, anyone know what is wrong. My field is set to formula.
=IF[USAGENO]=060,"Office",IF[USAGENO]=050,"Lobby"))
Thank you.
alex
This is how i would do it.
Select Case "[USAGENO]"
     Case "060"
          RESULT = "Office"
     Case "050"
          RESULT = "Lobby"
End Select
Notice the quotes around [USAGENO].  This will cast it to a string.  Also the quotes in the Case statement.  This also casts the values to a string.   I prefer case statements as it allows for easy upgrades in the future if you need to add more room names.
Hope this helps.
109 Kudos
Post 2 of 4
Re: Property Set Definition "if a number equals text"
08-08-2012 09:59 AM in reply to: alekzab
     Case "060"
          RESULT = "Office"
     Case "050"
          RESULT = "Lobby"
End Select
Hope this helps.
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2014 | Revit 2014 | EastCoast CAD/CAM V6.1 | Visual Studio 2013
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate. Thank you!
Active Contributor
0 Kudos
Post 3 of 4
08-08-2012 10:23 AM in reply to: Keith.Brown
It worked! thanks a lot for your help!
Alex:catvery-happy:
109 Kudos
Post 4 of 4
08-08-2012 11:17 AM in reply to: alekzab
I forgot to add this portion of it.  I always put an else statement in my select case statement as shown.  you could leave the quotes empty if you don't want to output a message but I always find it good coding practice to have in it there at least.
     Case "060"
          RESULT = "Office"
     Case "050"
          RESULT = "Lobby"
     Case Else
          RESULT = "** ERROR - Usage Number Not Found! **"
End Select
