If we move the location of a project, we get the prompt asking us to repath our projects.
We are in the process of automating and having theis prompt appear halts the process.
In several documents I see ther (use to be?) a "Do not show me later" chechbox .
for example:
This appears to have been removed?
Is there any setting or any other way we can avoid this prompt?
Solved by gpuerini. Go to Solution.
apparently there is no setting for this..
Autodesk has suggestted using the following approach..
http://thebuildingcoder.typepad.com/blog/2009/10/dismiss-dialogue-using-windows-api.html
I took the concept of this, but found the following web site a bit more helpful, and got a solution to work.
http://www.codeproject.com/Articles/24066/Intercept-and-Manage-Windows-Originated-by-Third-p
-GP
