I am trying to programatically create a new display representation style override on an existing wall style. I've found how to alter an existing override, but can't quite get how to make an new one. Can anyone point me in the right direction?
Public Shared Sub ChangeDispComponentOverride() Dim objDB As Database = HostApplicationServices.WorkingDatabase Using trans As Transaction = objDB.TransactionManager.StartTransaction Dim dicWallStyles As DictionaryWallStyle = New DictionaryWallStyle(objDB) Dim idWallStyle As AcObjectId = dicWallStyles.GetAt("1C10") Dim styWall As WallStyle = idWallStyle.GetObject(OpenMode.ForRead) Dim mngrDispRep As New DisplayRepresentationManager(objDB) Dim colIDs As AcObjectIdCollection = mngrDispRep.GetAllDisplayRepresentationsWorkForSpecifiedClass(RXClass.GetClass(GetType(Wall))) For Each idObject As AcObjectId In colIDs Dim objDispRep As DisplayRepresentation = idObject.GetObject(OpenMode.ForRead) Select Case objDispRep.DisplayRepresentationName Case "Aa-Plan Floor Typ" objDispRep.UpgradeOpen() Dim objDispPropNew As New DisplayProperties objDispPropNew.SetDisplayRepDefaults(objDispRep) Dim colStrings As StringCollection = New StringCollection() Dim arrayDispComps As DisplayComponent() = objDispPropNew.GetDisplayComponents(colStrings) If arrayDispComps.Length > 0 Then For I As Integer = 0 To arrayDispComps.Length - 1 Dim objDispComp As DisplayComponent Dim strName As String = colStrings(I) If strName.StartsWith("Shrink") Or strName.StartsWith("Boundary") Or strName.StartsWith("Hatch") Then objDispComp = arrayDispComps(I) Dim objDispCompEnt As DisplayComponentEntity = objDispComp Select Case True Case strName.StartsWith("Shrink Wrap Hatch") objDispCompEnt.IsVisible = False Case strName.StartsWith("Shrink Wrap") objDispCompEnt.IsVisible = True Case strName.StartsWith("Boundary") objDispCompEnt.IsVisible = True Case strName.StartsWith("Hatch") objDispCompEnt.IsVisible = False End Select End If Next I End If 'objDispRep.SetOverriddenDisplayPropertiesDefaults(objDispPropNew) objDispRep.SetEnforcedOverridenDisplayPropertiesValues(objDispPropNew) 'trans.AddNewlyCreatedDBObject(objDispPropNew, True) '** eNotInDatabase End Select 'Dim idOverride As AcObjectId = objDispRep.FindDisplayPropertiesOverride(styWall) '***need to be able to set a new override, not just find an existing one 'If Not idOverride.IsNull Then ' Dim objOverride As DisplayProperties = idOverride.GetObject(OpenMode.ForRead) ' Dim colStrings As StringCollection = New StringCollection() ' Dim arrayDispComps As DisplayComponent() = objOverride.GetDisplayComponents(colStrings) ' If arrayDispComps.Length > 0 Then ' For I As Integer = 0 To arrayDispComps.Length - 1 ' Dim objDispComp As DisplayComponent ' Dim strName As String = colStrings(I) ' If strName.StartsWith("Shrink") Or strName.StartsWith("Boundary") Or strName.StartsWith("Hatch") Then ' objOverride.UpgradeOpen() ' objDispComp = arrayDispComps(I) ' Dim objDispCompEnt As DisplayComponentEntity = objDispComp ' Select Case True ' Case strName.StartsWith("Shrink Wrap Hatch") ' objDispCompEnt.IsVisible = True ' Case strName.StartsWith("Shrink Wrap") ' objDispCompEnt.IsVisible = True ' Case strName.StartsWith("Boundary") ' objDispCompEnt.IsVisible = True ' Case strName.StartsWith("Hatch") ' objDispCompEnt.IsVisible = True ' End Select ' End If ' Next I ' End If 'End If Next idObject trans.Commit() End Using End Sub
