AutoCAD Architecture Customization
Welcome to Autodesk’s AutoCAD Architecture Customization Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture Customization topics.
problems with Table creation in Architecture 2012
3 REPLIES 3
rshamoon
323 Views, 3 Replies
Good Day to all,
I am running in to a problem when creating tables in Autocad Architecture 2012.  The problem occures when the table size has increased, for example, I recently created a "Room Finish Schedule" table and it is 11 columns by 200 rows.  When selecting a cell to edit, selecting the table itself, or to make any modifications once the table is selected takes a bit of time for the action to be exccuted.  Is there any way to speed the process or improve the tables.  I am not sure if creating two different tables rather than one would work better.   I am trying to avoid using Excell sheets that are pasted into CAD becasue of OLE issues I've run into in the past.
Thank you for your time,
Raman.
3 REPLIES 3
David_W_Koch
in reply to: rshamoon
Welcome to the Discussion Groups.
Are these AutoCAD Tables, or AutoCAD Architecture Schedule Tables?
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
rshamoon
it is a regular table.  I guess you can say an autocad table, but the software being used is autocad architecture.  we did not want to make a smart schedule, because it would just be used to input finishes within a space.
David_W_Koch
Others will have to jump in here, as I have very limited experience with AutoCAD Tables.  You may also want to post your question in the AutoCAD 2010/2011/2012 DWG Format Discussion Group, as you may find a larger pool of people there with AutoCAD Table experience.
David Koch
Blog | LinkedIn
”Boost
